Hi all,
I have a TBS Discovery for some time now, very good quad.
But when I saw arriving Discovery Pro I said I want it!
I almost had a heart attack.
So I decided to custom mine.
I had to make a well-considered simple and removable system.
So I bought a cheap gimbal for testing, this:
http://www.goodluckbuy.com/2-axis-gopro-2-3-brushless-camera-mount-...
Here is my first test, I posted there some time.
Considering the quality of the nacelle (plug & play), I decided to keep it and modify it to TBS.
I wanted to have a system in line with the Discovery, so I got started in the measurement and design to allow this.
I removed the unnecessary things.
Then I printed my adaptation in 3d printing.
The advantage of this system, I unscrew a screw and two cables unplugged, gimbal power supply and servo wire gimbal, and I can remove the gimbal to go for a real FPV flight.
That the Discovery Pro does not allow, because the gimbal is unremovable.
I am very satisfied of results.
The first flight with this custom
You can find the parts available directly on the Shapeways site at the following address :
https://www.shapeways.com/shops/polakshop
Enjoy ! This shape is perfect for the gimbal like a discovery pro ! And certainly less expensive!
Thank you for reading
Polak
