In this build video we cover how to build the Manic Micro nnTiger Moth. I walk you through step by step and reveal all my tips and tricks to help your build go smoothly. Get ready to use that pause button!
PLANS
SPECS
WINGSPAN
16in | 406mm |
LENGTH
13.66in | 347mm |
CHANNELS
4 |
WEIGHT
AUW - 80g |
ELECTRONICS
MOTOR - 5g NTM - hexTronik PROP - GWS 5x3 ESC - 6a Plush BATTERY - 300mah 2s SERVOS - 4x 1.7g |
BUILD DIFFICULTY
Beginner – You’ve never flown a plane before, let alone done a scratch build Novice – You’ve flown a plane but have no experience with scratch building Intermediate – You’ve flown and built a few FT style planes before Advanced – You’ve mastered the standard FT build style and are looking for a new challenge Expert – You’ve mastered all build techniques and aren't afraid to improvise or tackle tedious builds Intermediate – You’ve flown and built a few FT style planes before. |
PILOT SKILL
Beginner |
MATERIALS
2x BBQ skewer 1x sheets DTFB 1x sheet poster board Push rods Control horns Hot glue |
Join in the discussion on the forums!
PICTURES
Intro includes great footage of this Manic Micro in the air.
Index for your convenience!
This thing sure is small!
300mah 2s is the sweet spot for flight time!
Paper is strategically removed from the fuse to keep weight down and strength up.
Hooking up the servos can be a pain, see how I do it in a breeze!
Each strut is cut to the exact length required making the top wing effortless.
All square here!
It's the little details that make for the exciting presentation.
With a swappable pod you'll be able to build all the Manic Micro birds!
The completed nnTiger Moth is beautiful, great work!
If you build a Manic Micro nnTiger Moth, please make a post and share your work. I love getting to share in the experince with you. #nerdnicRC on Instagram your photos to share with others.
Thanks for checking out the Manic Micro nnTiger Moth! If you built one and enjoyed it please consider donating a few bucks so I can buy more supplies to make more great planes.
Another great design! I did miss where you mounted the receiver and what are your recommendations for securing the prop? A little insight please before I order the parts.
Thanks, WJ.
For the prop I got a big bag off ebay a while back but I've added a link in the SPECS to where you can find them now.
cheers!
I used a DYS d1410 motor and it worked well at 3/4 throttle swinging a cheap 5030. I have a 4030 to try next. Emax ES9251s worked great. For the RX I went with the FS2A 4CH AFHDS 2A Mini. A 300mah 2s powered everything for about 4 min till the 7.4v mark. AUW was 80.44g. It was pretty warm but not too hot after. It was 94°F and sunny that day though.The plane requires minimal throw in the ailerons. I used a bit too much and nosed it in on maiden launch. The firewall came apart after the second flight. I think I'll install a hatch on the bottom for the battery and permanently install the firewall to the fuse. Overall everyone at the field loved the plane and said it flew beautifully on the second attempt. Thanks for the most excellent build vid and plans. Hope to see you at FFE this year.
