As promised by Ashton, the build video for the MF-Typhoon. Many lunches went into this build, and staying true for his last two episodes of the program, he wanted to go solo. He did a great job and we hope that you get what you need out of this episode to build your very own Typhoon scratch build aircraft. If you haven't done so already, download the plans and cut out your pieces and get ready. You can also support the program and purchase the plane from Altitude Hobbies.
Plans: http://www.mesarc.club/#!plane-plans/ccb
Build Kits: http://www.altitudehobbies.com/mesa-rc-foam-fighters-kits
Step 1, cut out all pieces and crease all lines mentioned by Ashton. You can also bevel them too, depends on your preference.
Step 2 Fuse together the midsection piece.
Step 3 create the bottom fuselage piece.
Step 4 attach the midsection to the bottom belly pan piece.
Attached bottom flaps to midsection.
Step 6 glue the back closed
Step 7 form the main fuselage pieces.
Step 8 add the spacers
Step 9 Form the front nose bottom section
Step 10 Form the top nose cone canard piece
Step 11 Glue the both top and nose cone pieces.
Step 12 Form the canards
Step 13 Install the servos and extensions
Step 14 Glue the main top wing pieces over the front leading edge of the midsection.
Step 15 Install the motor and esc
Step 16 Attach the canopy piece.
Step 17 Glue down the control horns with push rods
Step 18 place battery in the laser cut section of the removable nose cone piece.
Step 19 Find the CG using the marked off holes and go fly!
On behalf of the MESArcFF Program, we would like to thank the FliteTest Community for supporting Ashton through his 3 years of the program. Each and every design brought to the table you guys watched and gave feedback too and that support has turned him into what he is today. We wish Ashton the best of luck in High School and we hope to see him back in our ELITE program.
Thank you,
MESArcFF Team
Maiden of Tyhpoon
Again, thanks so much for your support in the program. We couldn't do it without you.
I won't let you down.
-Ashton, MESA RC FoamFighters 2012-2015
