RedCloud and myself tearing around in our minis.
He is flying a Spidex micro, while I am loving my Minion,
a Carbon Fiber Mini H Quad designed by Pat G.
NAZE acro FC
ZMR 1804 2400kv motors
RCX 10A ESC Brushless Motor Speed Controller (G Series / Programed for Multicopter - SimonK Firmware)
RunCam Sky Camera-2.1mm lens.
200mw 5.8ghzVtrx
1W 2.4ghz booster.
The arms where designed in pairs to give them more strength and also to reduce the amount of fasteners needed in assembly, less fasteners mean easier assembly and a lighter frame.
With 100% pure 3K Twill Weave Carbon Fiber it's strong enough to be crash resistant. Nice!
The Minion has been designed around a 36mm size FC board to achieve the smallest size possible but still have it big enough to carry your standard FPV equipment. I have a Naze acro FC and I really like it.
Good to go.
=D Get out there and fly!
I don't remember seeing your build before, it is very clean.
A lot of my Spidex footage was filmed with this rig.
Thanks for the Kudos! You Rock.
I like to run CP antenas on my Tx just to avoid the 23db or so loss when banking, with the CP on the Tx the max I will loose is 3db ;)
Well here is a simple math. This frames can handle well at about 500g 600g it's more on the porky side it will fly sport still but it will probably be about the limit.
Now my minion is 400g with #16 camera and a 1400 40c lipo so if I add a gopro 3 that it's only 60g without case that will be 450g that is well with in the capabilities of the frame.
The gopro 2 is 100g so that one will put my Minion at 500g :)
Hope that answer your question
