The mobius action camera is a great, cost effective camera but if you've had much experience with one you know that it can be frustrating knowing how "charged" the battery is. Here's a quick tip to add an adapter to your mobius!
This mod will likely void your warranty so keep that in mind if you'd like to try this hack.
First you'll want to remove the two screws and open up the mobius.
On the battery you'll see the positive and negative ports you'll be soldering to.
In the top lid, drill your hole to feed your adapter through.
Test fit your adapter. We're installing a basic JST Adapter so we can test our battery with a 1-6 cell Tester.
Feed your adapter through the case and solder the adapter onto your leads.
If you're using a 1-6 Cell Battery Checker, you can tell which side is the bottom by looking for the 'dots' on the LED display. In very small print the ports are labeled as well. Starting from the bottom: negative,1,2,3,4,5,6.
And there you go! A mobius with a battery checker adapter. We hope this tip was helpful, we'd love to see what other mods you might have to share!
Do you know what the battery should be charged to?
4.22 volts is the a fully charged battery or in the middle?
Please advise.
