This is my first tricopter build ever. Inspired by the design of David Windestål I started building. Can't wait to maiden it.
1 Tricopter frame
3 TURNIGY 25A ESC UBEC
3 Turnigy D2836 750kv Brushless Outrunner
3 Gemfan 9x4.7
1 Emax ES3051 Digital Servo
1 KK2.0 Multi-rotor LCD Flight Control Board
1 3s Turnigy 2200mAh LiPo
1 AR8000 DSMX receiver (SPMAR8000)
1 TM1000 DSMX Full Range Aircraft Telemetry Module
1 Spectrum DX8
750KV motor spins 750rpm x voltage = final RPM
So to use a 11x4.7 prop would over Draw the motor and cause it to over heat and become destroyed. So using a 9047 4S setup would produce the same if not more thrust than a 1147 3s setup. You also get higher RPM which has its own benefits such as better responsiveness
- Ryan
