So i have the fatshark googles but i also wanted to add a 7 in monitor to my rig.
But i wanted to use the same power as the battery so i snaked it thru the old antenna hole. you can see the power wire mesh cables in the pictures. but i wanted to more directed leads so i had to open up the monitor and add my own cables.
Then i wanted to have kinda a NASA looking tx so i took everything apart and made it white.
This is inside the monitor. just had to find the video in and power in.
+9+;
monitor now mounted
Then decided to flash
I made my own plugs with some pins rows i found.
checking to make sure all wires are correct.
a couple of drops of hot glue so wires don't pull out.
shaping hot glue.
add a nub to mach the cable so i dont forget which way to plug it in.
perfect match!
Soldered wires to board checked it 3 times. better safe than sorry!
now flashing...
Done!
error is normal and reboot..good bye 9x!...HELLO ER9X!
ok Now i got bored with the radio so i decided to take everything apart and paint it,
I masked most of it any thing i miss can be remover with a q tip and some actone.
4 coats
I tought it would dry fast it drys to the touch in 1 hour but it take 7 days to get solid.
weather is soo nice i decide to put it back together after 3 days. i am painting another one fire engine red if i mess this one up.
Hoston... we have a go! for monitor!
everything is working ER9X looks good!
You can see wher i snake the power from the radio battery out the antenna hole.
the monitor mount is from http://polakiumengineering.org
the yellow plug is the monitor power that connects to the tx power.
I dremeled the pin mount shorter to fit my fr-sky pack and removed the aa batterypack and added a lipo battery.
battery connected with new plug and shrink tubing.
Connect plug.
Battery fit like a glove!
Now I added a Sun visor.
This should work!
Added my logo and mug shot to the radio to make really custom made!
Radio before paint job.
Hope you like my radio!
Please check out my new youtube channel and subscribe thanks soo much for reading!
http://www.youtube.com/tommygunnfilms
Tommy Gunn
so it helps teach you with out losing line of sight. as long as you not directly under the sun it best to be like under a tree or someplace shady. I also can remove it and let my friends watch while i use the the fatshark. and if anything else... it impressed the hell of people!
but i am using goggles more now and if you notice the blue velcro that is for a battery when i remove the monitor from tx i just pop a battery on the back of it and then people can share it or mount it on tripod. the monitor cost me like 32.00 bucks.
the battery was like 12.00 i just cut the leads off the AA battery tray and solder them on to the lipo battery and plugged it it the battery fits like glove! but do try to charge the battery thru the tx!!! you have to charge like any other lipo battery for this battery i have a small 2-3 cell balancing charger i got from one of my efilte models and i just plug the balance plug in and i am good to go.
this is the battery i use.
http://www.hobbyking.com/hobbyking/store/__16529__Turnigy_2650mAh_3S_1C_LLF_Tx_Pack_Futaba_JR_.html
first i am going change the antenna to a 7fb antenna when they come back in stock should add more distance or at least a stronger connection.
other ideas i am thing about is adding another 3 position switch the 9x only has 1 most radio only have 1 unless it is very $$$$.
and i am toying around the idea of adding voices to the tx so it talks to you like warnings, time switches etc. ie " gps engaged" Battery low" "manual mode engaged"
I have exactly the same monitor on my setup works well
Nice work sir,
