Nutball Unswappable
I have uploaded 2 photos of the aftermath of the first few flights of the Nutball, I had a reasonable maiden and 3 other good flights with it but on the 5th flight it suddenly " Nose Dived" and to the right straight into the ground. Is it a characteristic of this type of plane ?as this is the second Nutball I have built and they both seem to want to do this.
The first was slightly larger and made of foamboard not depron as this one.
I would be grateful of any flight info on this, not sure whether to give up on it and try a different scratchbuild.
Please take a look at Photos, sorry no video as yet..
I wonder if your "fixed" version of the nutball's fuselage does not change the downwash angle from its original design conception hold with barbecue skewers, or is it in fact like thejosh say, simply a positioning problem of your battery to find the right CG ?
Français ?
Je me demande si ta version "fixe" du fuselage de la Nutball ne modifie pas l'angle piqueur du modèle par rapport à sa conception d'origine calée avec les piques à brochettes ou est-ce en effet comme le dit thejosh tout simplement un problème de calage de ta batterie pour obtenir le bon CG ?
