Hey guys!
My Quanum FPV Bundle HobbyKing order just arrived.
.jpg)
After finishing all cables look completely disordered!
So I checked for a couple of solutions for a clean setup and someone solved the problem by a simple paper roll!
So I decided to solve my problem same but a better looking way...
First, I shortened all the extremely long wires one by one. These are;
- Receiver's power cable,
- Receiver's AV cable,
- and monitor's power cable.
First, I've cut and shortened the wires and soldered them back.
It's very simple, don't be nervous about doing it. Same cables, same colours, same ways, only shorter. You'll not ruin it, trust me! After soldering, cover the soldered points with isolated tape (the way I did) or you can use heat shrink tube if you have.
After this process, you're done with cables. Now it's time to give a better look to this paper roll. Here is my solution for that;
I covered the paper roll with self sticking carbon fiber film and here it is!
Now it looks clean and perfect with your Quanum Goggles.
You can get the carbon fiber from here; http://www.aliexpress.com/item/1-pc-Black-1-52-0-5M-4D-carbon-fiber-vinyl-film-4D-carbon-fibre-sticker/1869788252.html?s=p
(But i won't tell you where to get the paper roll! NO WAY! lol)
Then I used a piece of self sticking velcro to put the roll on top of the goggles.
You can see the result in the picture!
I stuffed all wires into the roll. Only left the connectors outside of the roll.
Covered the open side of roll with scotch tape in case of dorpping wires.
I mounted the receiver behind the goggle with double sided foam tape, and also put the receiver wires into the roll.
I permenantly closed the other side of the roll with carbon fiber tape.
Hope this is helps to make a clean setup for everone who has this bundle a simple and cheap way!
Greetings from Istanbul !
