We had the wonderful opportunity to spend a weekend with an awesome flying family from our community, Heather and Shane McDowell, aka Mr. and Ms. FlashGangster.
One of the most difficult things about making a durable race wing is the laminating process, so the McDowell family showed us how to laminate and shared some great finishing tips with us as well!
To laminate your wing, spray the painted wing with Super 77. Let dry for 15–30 minutes.
Place the wing in a scrap foam cradle, and pinstripe if desired.
Lay 3mm laminate over top of the wing. Starting from the middle of the wing, use a heat iron to seal the laminate. Work the iron from the middle to the leading and trailing edge of the wing.
After the top is done, flip the wing and cut reliefs to allow the film to cross over to the bottom. Seal the bottom the same way as the top.
Every wing is different, but we hope this will give you some cool tips to both finishing and building your own flying wing.
Thank you to the McDowells for sharing their knowledge and love of flight, and thank you to the Flite Test family for giving your time and talents to move this hobby forward.
Check out the McDowells' channels at the links below:
YouTube
FlashGangster
FPVTeamLegit
Instagram
Mr. FlashGangster
Ms. FlashGangster
Share your own laminating quick tips with us in the comments below, on our Facebook, or in an article!
http://www.flitetest.com/articles/how-to-build-an-epp-flying-wing
for a quick trial get some A3 laminating pouches, iron on with 1/2" overlap... the joins are strong and barely visible..
