This episode is sponsored by Audible.com
Flite Test fans can download a free audio book here: www.audible.com/flitetest
The RV JET from RangeVideo.com is an EPO flying wing setup specifically for FPV.
This foam wing features a an advanced gimbal system for GoPro 3 and micro cameras.
There is plenty of cargo storage inside this RC airplane.
The instruction manual for the RV JET is one of the best that David has even seen.
The pan and tilt advanced gimbal system features a clear dome camera covering.
A one-way mirror version is also available.
Unfortunately, we noticed that the mirrored dome caused reflections from the camera in the bright sunlight.
The RV JET arrives in a box that can also be used as a travel case!
This airplane tracks amazing! Even with hands off, the RV JET flew straight.
Not only does this airplane fly great, but this EPO plane looks amazing in the air.
The wings can be customized to be longer or shorter.
The shorter wingspan allows for fast, fun flying that is more responsive in the air.
Compared to the X8 and other FPV wings, we all really liked the RV JET better.
The pan and tilt system along with the dome covering allows for amazing unobstructed FPV flying.
More details about the RV JET available at RangeVideo.com
Awesome episode guys, as always!
How does the Caipirinha compare to the RV Jet?
You can't really compare the two. Both is good planes but different.
You should paint that, btw, bet it will be awesome.
Well, it is an FPV plane, and i would like to see a real FPV build for long range situations. (I know you have all the necessary gear in house) Because i would love to see how it glides, climb, cloud surf, you name it, since i want to compare with another fpv platforms, like the ZII and the ZXL.
Second, you dont fly FPV using the GoPro as video camera, and i would like to know if you can fit a second board camera inside that dome. Vova mentioned on YouTube that a micro one will fit. I would like to see that. (I know a lot of people do fly using GoPro's for video feed, but well, i have this thing with me that makes me listen to Trappy's advices everytime :) )
Come on, make another article and push this plane to his limits! We all want to see that! :)
An alternative can be to embed a micro camera in the LE of the wing close to the fuselage and add a video switcher. Then you can fly using your gopro and if (God forbid) the gopro dies you can fast, safe and easy switch to your micro camera for safe flight out of there. That enables an aerodynamic and nice installation that enabled you to fly using your gopro and still have the safety of another camera. Using a functional and reliable RTH-system such as the RVOSD provides can also add another level of safety if configured correctly.
I've personally have never experienced such a gopro failure and none of the ones I fly with have either although I've read about it on the net and I'm very aware of Sander Sassen's (ssassen) and Raphael Pirker's (trappy) opinion on this matter.
It is a very beautifull and functional frame, thats for sure!
Think it was chad that mentioned balsa needed before flying the short one BTW :)
This is the one I use. http://www.amazon.com/gp/product/B000O554MU/ref=oh_details_o03_s00_i01?ie=UTF8&psc=1
It was $12 USD.
-800mW 1.2GHz VTx with a three lobe SPW (called cloverleaf)
-Gopro2 HD camera
-ImmersionRC EzUHF RC-link with a 8ch diversity RCRx
I think David rushed the install a little though. The model is designed with invisible installs in mind and the vtx looks like it was just taped on the wing. :)
