Scratch Build Glider
Aircraft Platform : DLE-GL02-00
Tested Drive system :
- Brushless motor : Revox 2808-1900kv
- Speed Controller : Emax ESC 30A with internal linear BEC 5V/2A
- Electric Nylon Propeller : Revox 6x4E
- Servos : 4 x HXT (Hextronik) MG14, Metal Gear servo
- Li-Po Batt : Revox 3S-2200mAh (30C) Nano Tech OR Emax Tipple 3S-1800mAh (20C)
Radio Tx/Rx system:
- Tx : Futaba T8FG Super, 2.4 GHz transmitter
- Rx : Futaba R6028SB, 8ch 2.4 GHz receiver
Design review :
- Airbrake mixing is implemented to alter the elevator position for take-off (overhead hand-launch).
- The wing aspect ratio provides a good glide ratio when the wind condition is calm and/or catching rising thermal.
- The motor power is too high for the required spec, even though the motor weight is small. (high power to weight ratio).
When it is high up soaring in the Sky, the silhouette among the clouds is beautiful.
Here are some Flight videos:
D.L. Engineering -The Sky is Home
www.dle-tech.info
support@dle-tech.info
