Fourteen feet of wing holding 64 solar cells generating 60watts on a cloudy day to fly this monster with ease.
This was "donated" to us by the engineer (Jim Hynes) and Bulider (Fred Hesse) and is capable of 24 hour flight - soon as we add in some batteries that can charge during the day to be used through the night.
The elevator is wider than most park flyers at 45"
OK, technically it has one battery, but it is for the reciever. It is not wired to the motor at all.
My only suggestion is that Windestal needs to work on a discus-launch version.
Are you going to make a 24 h flight? If so, please put a camera onboard and make a few minute timelapse of whole flight. That would be awesome :)
I can tell you some information however. The fuselage is a balsa-plywood build 80" in length. The prop is custom hand-made and when unfolded have a 44" diameter. Wings are balsa i-beam spars with reinforcement rods and boxed sleeve connectors to set the dihedral. The mid and two end sections of the wings create the 14 foot span. The 64 "Sun Power A 300" solar cells are wired to produce an 18v output into the electronics for motor operation.
So you should be able to wire in the receiver as well, don't you think?
cool plane
