Hi from Spain!
Here is a hand thrown glider for our sons and newcomers alike, helps a lot to learn building techniques, aerodynamics, doesn’t require a lot of space and above all…it’s fun. For those of you with access to a laser cut machine, download the 3 files, laser cut the airfoil, print and stick the adhesives, follow the assembling instructions and you’re done. Those without, print the decals, stick them to the foam (it’s up to you to remove or not the paper, I don’t know the type of foam you have in USA, anyway the lighter the better) and cut the airfoil with an Exacto. Here you find the step-by-step instructions. Good luck!
Cristian - AeroAvia
European colors
American desert colors
LooseBruce
