AVRO aerobatics!
I've been a bit precious with this plane, avoiding too much adventurous flying until I got more comfortable with the way it handled. Now I'm getting the hang of things, it was time to push myself a bit harder.
Two mistakes high, and no zoom on my camera, so apologies for the small plane in the distance footage.
I'll admit I had a thing about avoiding building biplanes early-on in my build career - twice as many wings to build! But now, I have to admit it's a good way to pack a lot of wing area into a small space. The larger top wing on the AVRO (840mm) is the length of an A2 sheet of foam board, which is the size I can buy in the UK, so it's a very economical build. The very compact nature of the plane also means it can turn on a sixpence (a bit like a dime).
One thing I'm learning about very slow flying is to switch to high rates. If you look at my landings, I made a few approach errors because I ran out of control at the slower flying speeds. On this plane full up-elevator on low rates does nothing at those speeds, which makes it almost impossible to flare. All part of the learning curve!
Cheers, alibopo :)
-Nice job, Keep it up!
