PDF Template For Tricopter 2.5: https://s3.amazonaws.com/assets.flitetest.com/article_files/Tricopter_1365353510.pdf - See more at: http://flitetest.com/articles/tricopter-2-5-build-and-first-flight#sthash.vOIuteW5.dpuf
After my last video, I had quite a few people asking what flight times I got using Sunnysky 1400kv motors on my Tricopter so I did a little test.
Motor: http://www.buddyrc.com/sunnysky-x2212-9-1400kv-ii.html
I use 9xx4.7 props
I had a 2200 3s 35c battery running this and a GoPro Hero 3 on it, I got 10 minutes before the crash and would estimate adding another 3-5 minutes onto that, so the flight times are pretty long.
MY MAIN GOAL IS TO GET SOME OPINIONS ON:
Should I get an openlrs or frsky module to replace my spektrum dx7s, I'm not looking for range, just reliability. I have a futaba 8UAF that I scooped up and would use that to put the module fyi
Buddyrc.com is the new epbuddy.com. Its really reliable, I get my parts in 3 days for really cheap shipping since they are in the US, like $4 cheap.
I ordered an OpenLRS set from HK the other day to get an idea of how 433 performs when pushing for more range than that or flying behind heavy vegetation. Have no experience with OpenLRS so far other than watching rchacker.com and the flitetest episode with IBCrazy and reading HK's disclaimer ("requires computer programming skills" etc), but I suspect FrSky will remain my default choice (rock solid so far, easy to use). Could probably get even more range out of it with a patch antenna.
