This is a super easy wall mount hanger for your Bixler. An alternative to other hanging methods.
Materials you will need: aprox 4' of 3/4"pvc
6 -3/4" PVC elbows
6" section of 3/4" id pipe insulation
4 to 6 screws and anchors for mounting
Cut and assemble as per the pictures. You can use cement if you want but I just pressed everything together firmly. With the exception of the front "u" shaped piece, leave that one loose, Add the piece of foam to protect the plane. And secure it to a wall.
To use simply remove the front "u" shaped piece set the plane in against the wall and replace the front piece. Adjust the top two elbows to help hold the plane center.
