Here is a list of recommended components that you'll need for your Speed Build (Swappable Fuselage) Kits.
RADIO
Turnigy 4X FHSS 2.4ghz Transmitter and Receiver (Mode 2)
HobbyKing HK6S 2.4Ghz FHSS 6Ch Tx & Rx (Mode 2)
SERVOS
Hextronic 9 Gram Servo
Suppo SP-90 9g Micro Servo
Turnigy TG9e 9g Servos
PROP
APC-style Electric Propeller - 8x4E
GWS EP Propeller (RD-8043 203x109mm) (6pcs/set)
BATTERY
Turnigy 500mAh 2S 20C Lipo Pack
Turnigy 500mAh 3S 20C Lipo Pack
ESC
Dynam 18Amp ESC w/ 3A BEC
TURNIGY Plush 18amp Speed Controller
Hobbyking SS Series 18-20A ESC
Suppo 18A Brushless ESC
Motor
LazerToyz Blue Wonder 24g [2712-12]
HEXTRONIK 24GRAM BRUSHLESS OUTRUNNER 1300KV
Turnigy Park300 Brushless Outrunner 1380kv
Suppo 2208/14 1450kv Brushless Motor (Park 370 equiv.)
FOAM BOARD
ADAMS Foam Board - Dollar Tree Website
ADAMS Foam Board (Readi-Board) - Manufacturer Website
OTHER SUPPLIES
Push Rods: Music Wire .047
Linkage Stoppers D1.8mm (10pcs)
Linkage Stopper "Speed Clevis"
Click here to see: ALL The Flite Test Scratch Build Articles
http://tinyurl.com/2200kv-BrushlessMotor-30A-ESC package China suppliers like to sell in bulk and sellers here will do that however aliexpress is also setup for sellers willing to sell single items, retail, and ship direct to customer! This is huge! No Ebay, Amazon, or Paypal fees for the middle men! All it takes is patience to wait for shipping from China which can take a couple weeks, sometimes more. They even guarantee a full refund if you do not get your shipment! I don't think it gets any better than this! If you (or anyone else) have further questions feel free to contact me via my flitetest user name & have FUN!
You guys inspire me and i <3 you!!!
Keep it up and never stop!!!!!!!!!!!!!!!! ;)
I am going to running a Boy Scout Camporee based on Aviation. One part of the event is building and flying your own model. This cuts the cost down to size. Now all I have to do is get the electronics from HK in less than 3 months.
Thanks
I'm so glad you have made this an afordable hobbie.
Thanks
If you're really looking to get into the hobby, I'd highly recommend spending a little extra on the Turnigy 9x or 9XR radio. They're a little more expensive ($50 + shipping), but they're 9ch computerized radios that will last for your entire RC career, with no need to upgrade, ever.
As such, I find figuring out what connectors I'll need to hook it all up a bit confusing. I think ESCs use bullet connectors, but I'm unsure of the size and usually motors come without. Can you recommend the part for these connectors to solder on?
Also is there a separate part number for prop adapters that will fit these motors?
The 3.5mm connectors are more standard, but I find they are really large for these smaller motors/escs, and are really overkill.
Whatever size you get, don't forget heat shrink tubing! Really critical for these connectors so they don't touch each other.
you'll also need a connector for the battery side of things. This should match whatever battery you decide to get, but all of Hobbyking's stuff uses XT60 connectors (http://www.hobbyking.com/hobbyking/store/__9572__Nylon_XT60_Connectors_Male_Female_5_pairs_GENUINE.html)
Finally, the prop adapter will depend on the size of your motor shaft. This should be listed on the page of whatever motor you buy. Most in this size range are 3mm (http://www.hobbyking.com/hobbyking/store/__8240__Prop_Saver_w_Band_3mm_10pcs_.html), but be sure to check with your specific motor.
I think I paid $3 or so for 5 rods (3ft each) at my LHS, so they aren't that expensive.
I also have 2 park 450's in the garage, but that may be a bit to heavy any thoughts?
Sport: http://www.youtube.com/watch?v=S5tSMN_Q7bE
3D: http://www.youtube.com/watch?v=SIXX-qLRuUk
http://www.hobbyking.com/hobbyking/store/__5437__APC_style_propeller_8x4_E.html
http://www.hobbypartz.com/7x35.html
i just bought the 18a ESC, but will this same set up work for the ft3d or the baby blender?
i want to eventually move up but i'm scared the smaller motor/esc will hinder me from enjoying the ft3d or baby blender
thnx
I do have radio and reciever, only need the electronics for the swappable pod
I am looking to order electronics from hobbyking and a a kit from you guys.
Thanks
I am just starting so I am little confused.
Thanks!
Which charger do you recommend?
They will work but they are very limited and about their only advantage is price. The biggest issue with them is no model memory but they also lack other useful possibly essential features and they appear to have only one choice of receiver that can only be obtained from HK. Something of a dead end.
Better choices for an inexpensive radio are these made by FlySky and branded by HobbyKing....
They all have the essential features although the CT6B requires a bit of organization to take advantage of it
Hobby King 2.4Ghz 6Ch Tx & Rx V2 (Mode 2) AKA FlySky CT6B
You have to use a computer to set this up but there is quite a lot of after market support for it. The 6ch V2 receiver that comes with it also works with the other two TXs here.
Turnigy 9X 9Ch Transmitter w/ Module & 8ch Receiver (Mode 2) aka FlySky FS-TH-9X
This radio, TX-9X-M2, has lots of flexibility and it you are handy with stuff you can upgrade it to be a very powerful radio.
or this..
Turnigy TGY-i6 AFHDS Transmitter and 6CH Receiver (Mode 2) aka FS-i6
It can use the same receivers as the other two but also supports Flysky's new protocol AFDHS 2A with some nice small receivers.
Other choices to consider are the Spektrum 5e which is very basic but at least it is compatible with Spektrum receivers so you can fly a Nano QX or a Duet with it. Or better the Spektrum 6i which is similar feature wise to the three I suggest above but a bit more pricey. If you buy one of these Spektrums used make sure it is a DSMX version. It will have an X on the front. The older DSM2 versions are not as good because the DSM2 protocol can be problematic. It's fine if its a gift but only pay money for a DSMX.
Any other suggestions for inexpensive RX/TX Combos?
