Hi Flite Test world !
For my first project, I wanted to represent my country : France ! Most of the people think French people wearing a Béret, holding a baguette while playing accordion. Well, I've never worn a Béret nor played accordion.
Truth is : French people love Baguette ! (At least I do :) )
It is it ! Let's fly a Baguette copter !
I scanvenged 3 DT750s, 3 20 amps ESCs and the KK2.1.5 from my first tricopter (It flew over my house and smacked the asphalt, full of love, and at full speed). I just needed to order 1 more for each and 1030 slow fly props. I also brought The cheapest Baguette I could find (I will never waste good baguette :D ) and let them dried so they were hard enough to work with.
I just cut the Baguette with a little saw to have a nice cut and link them with a string.
Now I jus need to add the motors, the ESCs and the KK2.1.5 !
I also needed to flash the new ESC with SimoK firmware, as I did with the 3 older one but I don't know why I never maaged to... I just slapt it on like this, what could go wrong ?
Actually, it never took off. A part broke the under the motor because of vibration. I assume the baguette just scramble to easily.
I didn't give up and rebuild it using something that I use to play with when I was a kid. It's called "Pâte à sel". It's basically the same recipe as Baguette, but with a loooooot of salt. I think the English word is 'salt dough modelling' :
- 1 cup flour (self-rising flour should not be used as it will cause the ornaments to bubble up while baking)
- 1/2 cup salt
- 1/2 cup water (or more as needed)
It's a lot heavier (1,5kg - 33lb) but also a lot stronger ! I just connect a 4s battery and let the -heavy- bread fly :)
I almost hit myself during the test, the controls were strange. Indeed, when I mounted the motors, I didn't chech if they were on a flat surface, and parrallele : they weren't !
But at least, it flew ! :D
Bye from Bonifator :)
http://img1.wikia.nocookie.net/__cb20150206140125/starwars/images/d/d6/Yoda_SWSB.png
