Wren
The Wren is an ultra micro RC plane precision laser cut from high-grade 2mm balsa. The Wren has a wingspan of just 20cm therefore it can be taken nearly anywhere you want. It is a two channel aircraft so it has a working throttle and rudder. This makes the Wren a beginner plane to fly as well as a fun plane for advanced flyers. The Wren is very easy to construct.
SPECIFICATIONS:
- Wingspan = 200mm
- Length = 200mm
- 10g flying weight
- 3.7v 30mAh li-po battery
- Up to 10 minutes flight time
- 2.4 GHz transmitter and receiver
- Skill level = beginner – intermediate
- Range = about 100m
KIT
BOX CONTAINES:
- Precision laser cut parts
- Two 3mm neodymium magnets
REQUIRED:
- Jp Nano stick electronics
- Jp Nano stick landing gear
- CA glue (Medium thickness)
