Even though I cover everything in the video, here are the specs.
Motors(From this kit): http://www.rctimer.com/product_786.html
Esc: Two 30 amp ESC's
Battery: 3s 2200mah
Full four channel control, however I really only need rudder.
It does not have differential throttle and I probably won't add it since I really dont think of driving it around on the ground as its main goal as a plane.
I will add more suface to the horizonal and vertical stabilizer, hopefully improving stability.
If you guys want, I can make a video going over the dimensions.
I would write more, but I didn't make the video for no reason.
Hope you guys enjoy.
