I have a new favorite soldering iron. The Weller WPS18MP High-Performance. I picked it up from Amazon for 27 bucks and I love it. It has a green/red led that turns red when you turn it on and then within about 30 seconds it turns green when it's reached temperature. The cord is removable and the unit itself is very light. The work is all done in the removable tip which you can remove at working temperature due to the rubber coated base. The work tip is a nice fine point and shorter than traditional irons so if you are shaky like I am it's much easier to control when performing small tasks. It has a very bright white led that lights up the work area pretty well. When you are done with it you can lay it right on the table without worrying about a stand and when you're done you can turn it off or remove the cord and lay it down so kids like mine don't run by and pull it onto the floor. All in all I give it a 5/5.
Remember to rate and comment on the articles so I can keep making them better.
Keep up the great work!!!!!!!!!!!!!!!! ;)
