I was keen to try some aerobatics with powered planes but none of my existing motor gliders was up to the task. Too "glidey" and not enough rudder. So this is what I came up with. It uses a few different build techniques including a very narrow tail forming part of the fuselage and a full flying elevator.
It has a 1.2m x 180mm 12% chord Armin wing and a 700mm fuselage both made from 6mm depron covered with 75 micron document laminating film. That is the thicker of the commonly used laminates and it added lots of strength.
For the fuselage I usually cover the depron or foamboard with tape first then make it into a tube. This time I started with flat panels of uncovered depron.
The sides were glued on top of the bottom panel, which defines the width of the front area.
The tail halves were glued together giving the taper curve, then top and bottom panels added.
The fuselage was then covered with 75 micron laminate.
This added a great amount of strength, especially to the narrow tail area.
The 2826/10 1400kV motor is mounted to 5mm plywood with ventilation holes drilled out. Initially I built in some down thrust but I am still testing to find the right amount. Plastic washers can be added or removed to vary the angle.
The most radical feature of this design is the flying elevator. The whole horizontal stabiliser pivots on a 3mm carbon fibre rod which also acts as the spar. The rod passes through a brass tube glued into the tail. The inner diameter of the brass tube must be just bigger than the CF rod to give free movement but minimal wiggle. To hold the brass tube firmly there are 25mm discs of foam sandwiched between ID card plastic on either side.
Watch the build video below for full details
This plane has turned out to be a great performer with unlimited vertical and great aerobatic capability as well as being a surprisingly smooth flyer.
Overview and build video
Beginner's aerobatics and slope flights
Onboard views over Corio Bay on a lovely calm day
SPECS
Armin wing span - 1.2m (47")
Airfoil chord - 190mm (7") including 45mm (1.5") ailerons
Airfoil thickness - 23mm (12%) using 9mm formers
Spar - Skyshark P4X 7.5mm x 850mm, 57mm back from LE
Fuselage Length - 700mm (27.5")
Flying weight (2200mAh LiPo) - 770g
Full span Ailerons / Flaperons
Full flying Elevator
Large Rudder
TGY 9018MG servos x 4
