It's the tiniest quad we've ever reviewed! It's so small, it's even smaller than something slightly bigger!
The Heli-Max 1SQ comes in a Ready to Fly package with its own transmitter, or you can get the Tx-R (Transmitter Ready) version and hook it up to your own using the AnyLink.
The charger is also tiny, a small USB charger that you can hook up to any USB port.
The 1SQ has a Triple Axis Gyro System, or 'TAGS' for short. With this, the 1SQ is amazingly stable. The gyros help the copter know where it is in the air so it can correct itself for a smooth flight, indoors and outdoors.
The battery is a 250 milliamp 1 cell battery.
You can set dual rates on the included transmitter. High rates will give you more control authority but makes the copter very touchy. Or, you can dial it down to low rates for a smoother, slower flight. the controller setup makes it easy to set your dual rates the way you want.
The 1SQ is also very durable. You can smack it into a wall, person, or bear and chances are it will be fine. Just pick it back up and fly again, like nothing ever happened.
The 1SQ will be released soon, so be sure to get yours!
Find out more about the Heli-Max 1SQ on their website:
http://www.helimax-rc.com/helis/hmxe0834-1sq/index.html
its very stable and you can do a flip whitout hurting it , even whit less skills like me ... it is just fun
When It will be released and it can be found in Germany?
Thanks for this!
Brazilians Greetings from cold Germany!
http://www.youtube.com/watch?v=YQIMGV5vtd4
