In this episode of Flite Test Josh and Josh talk about the Rad Jet! Not only are they reviewing the 800mm, but also the 420mm! Watch as they put them through the test.
Flying Environment - Outdoor
Experience Level - Intermediate
Power Type - Battery
Number of Channels - 4
Frequency - 2.4 Ghz
Aircraft Type - Jet
Prop Diameter (in inches) -
Prop Pitch (in inches)
Battery Capacity (in mAh) - 1300
Battery Cells - 3s
Build Type - PNF
Motor/Engine Size - 1850kv
Airframe Material - EPO
Frequency - 2.4Ghz
Aircraft Type - Jet
Battery Capacity (in mAh) - 180
Battery Cells - 2s
Build Type - PNF
Motor/Engine Size - 3000kv
Airframe Material - EPS
What about the CG of this plane?
How is better to set this?
I found that this one, is a bit wrong respect manual.
Can you advise about correct location and any trick.
Thk guys.
Glad you guys reviewed this one. I just purchased Flyjet X 83 with a 64mm EDf system all from Hobbyking. Still putting it together but looking forward to the first flight. This review gives me some idea what to expect. (Flightdeck)
Thanks..
