Leave it to Peter to pick up one of the wierdest RC models we've seen to date. This is the AC-10 Gyrocopter by Unique.
Unique is the best word to describe this thing too. The 1320mm rotors have no motor basically making this a flying windmill.
Some autogyros have a pre-rotator motor to give the blades a kickstart, but this relies on wind.
The guts feature a 4250 outrunner motor with a 60 amp ESC (4S 14.8V 3000-3300mAh Lipo battery recommended)
Peter being the only one who's actually flown one of this crazy machines, was a little more excited than the rest of us.
Flying autogyros takes a lot more attention to the craft and the surroundings (a.k.a. situational awareness) than normal fixed wing flying.
Also, more attention to which direction is down wind. When flying downwind the thing has a mind of it's own!
The biggest challenge is keeping the blades moving at all times during flight.
Maintaining proper head speed is done through throttle and pitch management.
Too slow of a head speed will cause the gyrocopter to roll violently to the left. The inertia of the blades will carry the entire gyrocopter over and crash.
At the end of the day, there is nothing quite like the "thwop" of the gyros blades.
This is a blast to fly, but definately not for first time flyers. If you are looking to challenge yourself as a pilot and step out of your comfort zone, this might be just what you're looking for.
If you are interested in gyrocopters but a little intimidated by the price, you might want to start with the simpler Durafly Auto-G2.
In either case these are something out of the ordinary. If you are looking to shake it up at your flying field, gyrocopters are the perfect way to do so.
I challenge Peter on making a swappable gyro.
Go Go Go!
There is so little information about gyros.
is a good paper on autogyros and their principles.
https://www.google.co.uk/search?q=model+autogyro+plans&biw=1920&bih=953&tbm=isch&tbo=u&source=univ&sa=X&sqi=2&ved=0CCAQsARqFQoTCOCKqOzVwscCFUZvFAodSqAAYg
Many many model autogyro plans
Usually negative local angle of attack is provided to help rotor turn initially, but it greatly restricts the rotor RPM. The advantage of having a small positive angle of attack is that it allows high RPM to rotor, but demerit is that rotor can't spin easily when exposed to wind, instead RPM needs to be induced by connecting the engine to the main rotor for some time until main rotor picks up speed.
Cadilus 5E does have an extra motor that gives an initial high speed spin to the main rotor, therefore the local angle of attack is not necessary to be negative.
Of course, a conventional rotor blade of helicopter can be used, but local AOA must be very small, compared to helicopter. That is why pilot suddenly lower the collective during an engine collapse, in order to set the rotor into auto-rotation. Also there need not be provision for pitch altering, a simple rotor head is sufficient.
If you have any doubt about Autogyro, reply below....
Actually, it would be better to outfit a model like this with a clockwise prop, so the motor torque counters the tendency to roll left at low headspeed. I tried it in my early gyro-times, but it's better to just get the head up to speed :)
Actually, isn't the sound the blades make a demonstration that the blades do flap? I thought flapping is the origin of that sound.
Gryf
I have experience with the HK auto-g. Pretty good machine, although quite tail heavy. I made my own (swappable!) autogyro, here is a link to the forum topic: shameless plug. Includes plans and a video!
http://forum.flitetest.com/showthread.php?10396-FT-style-(swappable)-autogyro!
http://www.cartercopters.com
http://www.youtube.com/watch?v=CFNc1iY8wi0
https://www.youtube.com/watch?v=5zj_JtleHlM
Cool meter is pegged of the chart with the Gyrocopter, great choice Peter!!
Justin
Used 5mm foam and BBQ-skewers mainly. Rotors have steel bearings. Just hot-glued them in. I use a CC3D to control it, as I'm not the best of pilots :) It's powered by an Emax XA2212 1400kv with 8045prop. battery is 3s 2200KWh. TOW is about 800gr.
