this is my XP-7
side view getting graphics put on
finished plane lookin sweet!
so heres the build i used the blender prints for the body
as you can see its a little bigger the body is 37in with the rudder
looking down the formers
the body is 3 3/4 at the leading edge of the wing
looking down at the battery compartment
used front compartment for the battery allowing for movement back an forth for cg
added some support inside to make less floppy where the wing mounts
body covered in construction paper
for the wing i used the cruzer prints it is 9 1/2 inches wide same folds as cruzer though
wing is 46inches long and goes from 91/2 to 7inches at the tip
at the tip it is 7inches
i brought the top all the way out flush with the bottom
at aileron i added one strip inside to keep it the same as the wing
ready for graphics
