Here it is! My best wing yet!
A look at the underside. I routed in a line in the EPP for the carbon tube with a dremel. That was probably one of the hardest parts of the build.
I put the winglets at a slight angle and reinforced them with small carbon rods at the base.
5 gram servos where used with carbon push-rods. I cut a piece of extreme packing tape in half and used welders glue to secure it because I ran out of blenderm.
Just a simple power system. I used a blue wonder, 8040 prop, 10 amp ESC, and a 3s 450mah pack.
Here's a closer look at the top of the wing. It has great potential for FPV, due to extremely stable flight and no pitchiness. It's also great for combat. I will soon post a video for more information and flight footage. Upon request, I would be more than happy to provide plans. A second version of the Delta G should come pretty soon!
Thanks a lot!
Giles
what kind of flight time do you get out of that setup?
i my self am researching for a setup that will fly the longest.
you took a small motor, ESC and lipo, things i think are the key to long flight times.
