Hey it's me Val0modelisme ! The French Man ! and today i want to present you my new FPV project : The Tigrish !
I created the Tigrish for to fly slow and stable with HD Cam !
Specifications :
Wingspan : 1260mm
Lenght : 1030mm
Weight : 990grs Ready to Fly with FPV system !
Clark Y profil and double dihedral
Full Depron (3 & 6mm Foam)
Equipment :
Motor : Turnigy Aerodrive D2830 1000kv
ESC : Turnigy Plush 30A
Lipo : Turnigy 20C 3s 1300mAh ------> autonomy = 8min ; but it can fly easy with 2600mAh !
Servos : 2x HTX900 9grs
Receiver : 2.4Ghz HK 6Ch
FPV Equipment :
Tx : 900MHz 800mW
Camera : PAL Cam
Antenna : ''IBCrazy BlueBeam'' or ''rubber duck''
HD Recorder : GoPro Hero 3 Silver
France Haute-Savoie Alpes
Evian factory {water}
If you want see the flight : Watch from half of the video
Chris
Observations... I notice you have not inclined the motor to change the thrust angle. My build of the "Smash Drone", a similar foam board pusher design by Cstence, flew MUCH better after I changed the thrust angle. Before the change - when I applied throttle the plane went 'dead' and was reluctant to climb. After the change - the plane was much more responsive and flew very freely. I'm sure the flight times were better as well.
See my logic in these articles;
http://www.flitetest.com/articles/find-your-centre-of-gravity
(At the end you will see the Smash Drone and how I decided on a new thrust angle.)
http://www.flitetest.com/articles/yes-it-s-a-smash-drone
(Explanation of changes , plus before and after video showing modifications to design and performance improvements.)
On your plane I would find the TRUE CG and then direct the motor thrust through a point a little above it (1-1.5cm?) - to allow some of the thrust to counter the additional drag force that comes from the wing when the throttle is increased. I think you can change the thrust angle easily with a few washers under the bottom two mounting arms on the motor. JUST a suggestion though :)
Can I ask what your AUW is with the 1300mah & 2600 (2x1300?)mah battery?
Cheers, alibopo.
I know for the thrust angle it's not good...
Thanks for the advice !
But i don't understand : What is the ''AUW'' I don't know this word in english xD ?!
The - AUW - stands for "All Up Weight". What does the plane weigh (grammes) when it is ready for flight with a full payload of batteries, camera and FPV gear?
It would help me compare it to my Smash Drone - 950 gm (with 2000mah LiPo)
Thanks, good flying :)
For the wing i use just 3mm Foam (Depron)...
i think is better to ask on the forum of Flitetest...
What place in France is that? I visited France some years ago, but just Paris and Loire (Amboise).....
Cheers
Giorgio
I'm happy to join your community. This is a great plane so I am wondering if any pdf plans are available.
Sorry if I missed out links that might have been posted in that regard :)
Cheers !
For now i don't have the time for draw the plan but i think it's for soon !
val0
Thank you in advance for your reply.
Frank
