Josh and TJ check out the E-Flite Cessna 150...and then they crash.
What we liked
- The PNP (plug-n-play has easy to connect wings
- Can be assembled in less than five minutes—push and twist lock set
- AX3S SAFE mode available to bind—but can turn off to get more aerobatic flights
- Great for intermediate pilots, and a great first BIG plane
- Beautiful shocks in the front—incredible landing gear
- Tremendous scale detail
- Versatile plane
Get your own E-Flite Cessna 150 here!
Specs
- BNF (bind-n-fly): need your own transmitter and battery
- Wingspan: 83.7 in (2125mm)Length: 61.8 in (1570mm)
- Flying weight: 8.9-9.9 lbs (4-4.5kg)
- Motor size: 50-size brushless outrunner (installed)
- Radio: 5+ channels
- CG: 95-105mm back from leading edge at wing root
- Recommended battery: 4-6S 4000mAh LiPo battery
