Quique from Flex Innovations teaches Josh to fly 3D on the Mamba biplane.
The Mamba has three flight modes that you can change with the flick of a switch:
1) High speed 3D
2) Sport
3) Slow speed 3D
The best part? The PNP (plug-n-play) version is able to be flown (after assembly) straight out of the box!
| Specs: | ||
| Length: | 43.4" (1102 mm) | |
| Wingspan: | 40.7'' (1033 mm) | |
| Weight: | 54 oz. (1520 grams) with 3S 2200mAh | |
| Wing Area: | 691.3 sq. in (44.6 sq. dm.) | |
| Channels: | 6+ (recommended) | |
| Battery: | 2100 -to- 3300 mAh 3S 40C+ LiPo | |
Want to add the Mamba to your fleet? Go here: flitetest.com/purchaseflexinnovationsmamba
