There are a few options when looking at FPV cameras. We took a look at the good old board camera, the Mobius, and the GoPro.
The board camera is the best for someone just getting into FPV. They range from $15 up to $200 depending on what you are looking for. The dynamic range of the sensors on the board cameras allow for cool things like IR perspective and night vision. Obviously these options will be on the more expensive range of cameras but this is something that the action cameras lack. On the flip side, board cameras can not record your video out of the box.
If you are looking to record your flights and have great quality footage, the action cams are the way to go.
The Mobius is a great affordable way to record and get fantastic looking footage. We have started to use the Mobius more and more on the show since we pick up a few and were extremely impressed with the quality. They come in a narrow angle view and a wide angle view. Keep in mind, with the action cameras, you will also need to pick up a video-out cable that is NOT included when you get the camera.
Now the top-dog when it comes to action cams is the GoPro. These are used for pretty much everything in the sports and cinema world and they also make fantastic FPV cameras. This is the best quality footage that you will be able to get out of your recorded flight, but that's if you don't mind paying for it. Same thing with the Mobius, this does NOT come with a video-out cable, so make sure you get that as well.
We did a few tests to see how the Mobius stacked up with the GoPro. Here you can see the dynamic range between the two cameras. They react to light differences in their own way. Watch the episode to see more!
Another difference was the angle of view. The GoPro does have a wider field of view but the Mobius does offer a wide-angle version that brings it a little bit closer to the GoPro. Here is the GoPro next to the narrow angle Mobius.
Regardless of what you choose, this is only a small portion of the FPV setup. Goggles, transmitters, etc. will also be part of your purchase so shop around to see which fits best into your budget.
We hope this episode gave you some insight! You don't have to break the bank to get what you are looking for, just take your time and look at all the options.
Have a different camera that you absolutely love for FPV? Let us know! Chat it up in the forums!
Really nice videos with it, specs, almost as the same as the GoPro.
Check this video (https://www.youtube.com/watch?v=4l8JD_lGYrg).
I wish you touched on latency a bit. It makes a big difference when flying FPV.
https://www.youtube.com/watch?v=Xp4tU69Oehc
Its slightly thicker as the GoPRO but has 2,7k Resolution for 70$ (http://www.banggood.com/Original-XiaoYi-Ambarella-A7LS-BSI-CMOS-WIFI-Sports-Action-Camera-p-969228.html) you just need to fix the Focus for FPV and set it to 2,7k with a Script :)
