This video shows the first time I took the FT Bloody Wonder out flying. This is the first RC plane I've flown. I chose the Bloody Wonder because I thought it looked alot cooler than the entry level planes. I've played my share of airplane video games so I'm somewhat familiar with how the controls of the airplane work. I also have been flying a toy micro quadcopter to get more use to not overcompensating on the transmitter sticks.
Here are a couple of pictures of this Bloody Wonder after I added strips, a sunburst, and a FliteTest logo so I could tell up from down when it is flying in the sky.
I liked the Bloody Wonder so much I ended up building another. The first was retired and now hangs in my garage. The second one (shown below) survived a few flights until the speed controller over heated and shut off and cause the plane to nose-dive into concrete. It bent the shaft on the motor real bad and smashed the front nose enough that it wasn't really able to be salvaged. Maybe I could have done more, but I was too sick that it crashe like it did. Oh well, I guess I'll eventually build another. Here are a couple of shots of it. I spray painted it with 2x spray paint from Menard's.
It is however a hard plane to start out with since it is unforgiving to pilot errors. If you point it in the wrong direction, it goes there very, very fast. After all, It is built to be an air combat plane.
The plane has a relatively high landing speed. If you use a fixed prop mount on this plane you will break a prop pretty much every time you land. If you use a stiffer prop you will end up destroying the motor mount instead. Get a propsaver mount instead. That way you will save 9 out of 10 of the propellers broken by belly landings with the Bloody Wonder. The cost of a prop saver is roughly the same as a prop or two, so you will be on the plus side after the first flight.
Cheers Arend
http://flitetest.com/articles/maiden-flight-of-the-nut-job
