FTScratchBuild-Advanced
FT MIGHTY MINI MUSTANG SPECS
- Weight without battery: 5.5 oz (156 g)
- Center of Gravity: 1 inch (25 mm) from leading edge of wing
- Control Surface Throws: 12 ห deflection (elevator/aileron/rudder) Expo 30%
- Wingspan: 24.5 inches (622 mm)
- Recommended Motor: 2200 kv 2204 size motor
- Recommended Prop: 6 x 4.5 prop
- Recommended ESC: 12 amp minimum
- Recommended battery: 800 mAH 2s or 3s
- Recommended Servos: (4) 5 gram servos
FT MIGHTY MINI MUSTANG PLANS
STORE LINKS
- FT Mighty Mini Mustang Speed Build Kit
- Electronics Pack (Power Pack F)
- Electronics Pack (Power Pack A)
- Transmitters
- Receivers
New to the R/C hobby?
Here's some resources to help get you up to speed!
Beginner Series: WATCH HERE!
Electronics Setup: WATCH HERE!
First Flight Quick Tips: WATCH HERE!
Got glue?? Get Some Here!
I realize it's a break from the pure Mustang aesthetic, but seems like it'd be worth the trade-off for many folks.
i am working on the F-82
Also do you know the weight of the paper on Adams Rediboard? Weight in grams per sq. meter (gsm) would be great. Thanks
If in the US dollar tree foam board is about 5mm and very similar, if in the U.K. Hobby craft do west foam, which is 5mm but paper removal is impossible,
Yes, the mini mustang will fly on a 1806 motor, my first one was built with 12g metal gear servos and an 1806 motor , the test flight was done on a 5030 prop and it flew great, just make sure you get all your weight forward enough to balance. I have since changed the prop to a 6030 for more pull and have a 6040 to try.
I've also built this with 5g servos and a 2204 motor but haven't given it a test flight yet.
Thanks for the help. Love the planes and plans
Wow, she is quick, running the emac 2204 motor with 6045 prop.
Even on low rates the turns on a dime. Fantastic second or third plane,
She did get buffeted by the wind quite a bit, but in calm weather she will be so much better.
Great plane absolutely love it ๐
What do I build next?
Have built
Storch,
Bronco,
Tiny trainer,
Se5,
Both 22s
Bravo
Guinea pig,
So what's next ๐
Please help me I'm beginner ...
If yes then how much shud I take
about the FTScratchBuild-Advanced, the 'Advanced' refers to the build or the flying skills or both ?
Thank's, Marc.
But i will be building a second one and on that i am gonna sink the servo's into the wing by cutting a hole just leaving the paper.
Like more people are mentioning the cuts for the servo's are not shown in the build plans so maybe someone could add those ? Also there is a hole in the bottomsheet A ( For landing gear i guess ? ) that could maybe be marked as optional since it's not really needed when not putting on wheels.
Great little plane and hope to fly it soon !!
