FTScratchBuild
This is the step by step tutorial for building the FT Pun Jet, the Mighty Mini airplane designed with optional folding wings.
The FT Pun Jet was first featured in our FT Guinea Pig episode (Watch Here). After it's debut in that episode, viewer comments requesting that the swing wing experimental plane become a Speed Build Kit lead us to make it available for you!
FT PUN JET PLANS
The FT Pun Jet is available as a Might Mini Speed Build Kit in our online store HERE!
This foam build kit is made up of just a few foam board peices.
Code named "the cupcake", this 'swing wing' plane went through many changes before its final design.
You can create your own Z-Bends with a pair of Z-Bend Pliers: Available Here!
Peter came up with an easy way to magnetize his screwdriver by placing this Neodymium Ring Magnet around it which helps keep the tiny screw attached when installing servo screws!
The OLFA 5003 L-1 18mm Ratchet-Lock Heavy-Duty Utility Knife is our new favorite blade.
Designed to offer a servo-operated 'swing wing' but can also be flown as a straight-wing or glider!
Powered by the Maxx - MT1806. (Available in our Mighty Mini Power Pack A)
SPECS
- WEIGHT: (w/o battery) 4.1 oz (166 g)
- CG: 7.25 in (184 mm) from nose
- THROWS: 12° - 16° deflection; 30% expo
- WINGSPAN: 14.5 in (368 mm)
- *MOTOR: 2200 kv 250 size motor
- *PROP: 5 x 4 minimum
- *ESC: 12 amp minimum
- *BATTERY: 500 - 800 mAH
New to the R/C hobby?
Here's some resources to help get you up to speed!
Beginner Series: WATCH HERE!
Electronics Setup: WATCH HERE!
First Flight Quick Tips: WATCH HERE!
Got glue?? Get Some Here!
FT PUN JET PLANS
STORE LINKS
- FT Pun Jet Speed Build Kit
- Electronics Pack (Power Pack A)
- Batteries - (500 - 800mAh 2s / 3s 20c Lipo Battery)
- Transmitters
- Receivers
for new plane designs Peter will create for us Flite Test Junkies. Keep up the great work all of you talented people and much success. Flite Test Junkie that sounds like a T-Shirt... wink wink.
I just want to say that this little plane looks great and you guys are doing a great job.
I really like Peter's Designs , and i can't wait for his next great idea.
I just finished my first scratch build on foamboard (FT Delta) , but unfortunately i can't peel the paper off that easily, because here in Germany you can not get DTFB. What can i do to create such smooth bends anyway?
*wave*
It relates to the screw thread in any case not the motor turning direction, brushless motors can run either way.
The CW thread is for use with normal rotation props as the nut would generally stay done up.
Bit of threadlock would prevent it coming lose if rotating in other direction anyway.
Not sure I would ever use the folding wing, so thinking I would just build it with a solid wing. Any issues with this?
I don't like gluing in the motor mount with these motors, as this makes them non-removable. I fixed that as follows:
- Make two firewalls, both with tabs (left and right would probably be better, top and bottom is easier to install)
- Drill M3 or 1/8" holes through all tabs, so that the firewalls align.
- Glue and/or tape one to the back of the plane as usual, no motor.
- Mount motor on other firewall.
- Use M3 bolts to hold the two firewalls together.
The drawback is that the weight shifts back a bit, and you add a firewall. The plus is that you can now replace the motor, switch wires or disconnect the ESC for another plane without it being awkward.
A 1000mAH battery fully forward balances it out nice.
Motor mount held up though.
Not a beginner plane, speaking as a beginner. Going to add some LEDs to the bottom for orientation.
Peters build used 0,0 for down and side thrust as stated in video and flew fine.
Maybe yours is not square a needs a little side thrust.
When launching try 1/2 to 2/3 throttle and only go full once flying.
The 5mm stuff I got in UK is actually 5.5 - 5.8mm thick and heavier, so requires adjustment of plans to get slots and folds right. CoG usually needs bigger Motor and battery to achieve due to heavier foam behind the CoG.
Thanks
Can i use 1200kv Motor for this ?
Love this build :)
I would like to do this however would like to change it a little ...... if thats allowed, i would like to do an EDF version :)
Is there a way to get a DXF or Cad file for this???
also could you recommend a budget control set please?
