After watching the Flitetest video of the NAZE32 setup and the use of dihedral on the arms used with the rotorhub I decided I needed to try putting some dihedral into my next build.
It just happened that I was in the process of looking to build a new arco quadcopter. I have been using my ZMR250s mainly for LOS flying and acro, but wanted something a little larger.
Part of that process was looking for a frame. I was also on a tight budget so the starting point was almost decided for me. I ready had the ESCs and some motors and the FC. So wanting to limit the investment I chose to use what I had.
- Turingy D2830 1000kv with prop adapters (requires cutting shafts)
- RCTimer prop adapters
- AFRO 30amp speed controllers
- NAZE23 FC
- 8x4.5 - 10x4.5 props
So with these parts the options were limited. So I finally dececided on a Hoverthings FLIP sport. It was in budget, and I already have a Hoverthings frame so if nothing else it can be used for spares for my main camera ship.
I designed the mounts to add 5 degrees of dihedral. I use tinkercad for my simple designs.
The first part was to get the standard motor mount holes in the right orientation to to allow the 5 degrees of angle. The mounts also had to be recessed so that they were out of the way when bolting to the arms.
The Hovethings arms also have 3 holes around the edge of the arm which were perfect to use as mounting holes for the completed motor 3D printed parts. It took a little bit of figuring out angles and getting everything lined up. But once done I printed 5, (For WHEN I crash and break one)
Here is one full mounted up on the Hoverthings arm.
On a the completed FLIP Sport frame.
I also made some feet for the frame. As I was trying to make it as thin as possiable.
The complete build of the FLIP is here (Including parts used)
Next is flight testing, I have only had a chance to run a couple of batteries through the FLIP since its completetion. Heres a video of its first flight.(Sorry about the lighting)
3D Files can be downloaded from Thingiverse
http://www.thingiverse.com/thing:693900
The next step is to make some mounts that have the right angles to add to other Hoverthings frames that are not standard x configurations (FLIP 360, FPV, FPV Pro)
UPDATE :
Next day, better light second test flight and first crash. The frame is strong and the 3D mounts held up well.
Some raw footage with a 2200mah 25c battery. this time with balanced props and lock nuts instead of the prop adaptor cones which are badly balanced.
http://www.bluefish.net.nz/2015/02/flip-sport-build-for-acro-flying.html
