At Flite Test we’ve gotten to see some stunning planes being created with 3D printers. Whether it is made fully out of a printer or is a combination of foam board and 3D printed parts, the RC hobby is truly getting taken up to the next level.
Because we love the how a 3D printer can amplify RC in positive ways, we wanted to show you how to assemble a Forge 3D Printer in under 10 minutes and how to create your first printed RC part to complement your plane! Watch the video above for the full tutorial.
Take the printer out of the box and place on clean, level workspace
Get a friend to help you. It’s surprisingly heavy for how compact it comes in the box.
Read the manual before assembly
As with any machine that requires assembly, it’s important to read the manual before you start hooking things up. Even TJ made sure he read through it step-by-step!
Follow all instructions exactly
For more detailed step-by-step instructions, watch the video above. However, don't merely rely on Josh and TJ. It is imperative that you read the instructions to get it set up properly and to be able to print successfully.
What are you most excited about being able to print with your own 3D Printer?
i made a 3d printed FT Simple Firewall and used it on my FT Snowball
There is a ton of info there that pertains to this printer (and related clones) specifically.Tips, tricks, upgrades, help, etc. It is an amazing trove of knowledge and support.
Also this link: http://3dprinterwiki.info/wiki/wanhao-duplicator-i3/ has just about everything you need to know.
Very excited to see what you guys come up with in terms of models. As always keep up the excellent work!
http://www.thingiverse.com/groups/flite-test
Exchange ideas, help with issues, and generally work together to create awesome stuff!
I'm hoping when FT starts to post their files, they will also add them to the group.
Note: when setting up, make sure the two vertical z motors have the bars square. Mine was not. All you need to do is set the home all then turn the machine off. Get a set square and adjust the right hand motor manually until the bar is perfect 90 degrees. I was worried for a while there but it printed fine after that. It appears to be really fast in comparison to my old Printrbot I built a couple of years back.
The bed connection cable also gets in the way so I'll probaby tape a harder flexible post to it so it doesn't get in the way. Looking forward to printing big now. Cheers everyone.
Also note my Design Tip on the forum, it has been really handy - http://forum.flitetest.com/showthread.php?32372-Hello-from-Australia-and-a-3d-printing-design-tip regarding Windows 10 - 3d Builder app.
