Hello everyone!
The jello it's a common problem that many have with Mobius mounted on Multirotors. For solve that issue I made a simple vibration damper that solves the problem very well. This kind of vibration dampers are used also in industry and they work very well to RC and you will see ;)
All you need to build the isolator :
-Wood (Two plates 45x45mm)
-Bolts
-Nuts
-Washers
-Steel cable (I used 1mm)
-Rubber Bands
-Cable Fixer
-Foam
On next video you will how was before to use this, and after :popcorn:
And for results even better I made this update to my previous video and the results are even better!
Hope you enjoy this simple techniques and also build some vibrations dampers if you need them ;)
Thanks,
Gonçalo
