this is my version of a 60inch plane i already own so i decided to do my own version from foam board
this is the body i traced from an old one i had that was pretty much finished,
its cut from one sheet of foam,i had to add more to make up the lenghth total body length is 45inches
the wing design came from the ft cruzer plans with a few mod's to the size it worked well
i used an old wing joiner i had to join the two halves an used foam to finish the wing spar
finished wing and it is really strong and really light for 60 inches
for the rudder an tail i used the tail from my old sensei to make the plans for the new elevator and rudder, for the rudder connection i used some old control rod did some bends and glued it to the bottom of the rudder
old servo horns work well for rudder connections!
more old control rod to join the two halves of the elevator
cuts for the tail to set in for allignment
rudder control rod in place
rudder an elevator all in place
i know scary looking huh!!!!but it works well and holds the weight of the entire plane!! its an e-flite 480 with a hobbyking 45esc and an 11.1 2200mah
now its really comeing together!!!
battery box is located in the front of the plane for cg purposes it is perfect!
plenty of room in the servo compartment
front landing gear mount was going to make it steerable but opted for the locked in position front wheel,
here it is finished project!
Brian L
