Community member Andres joined Josh to discuss his gigantic 8-foot-wingspan P-38 Fowler Flaps build.
The P-38 was made primarily with Dollar Tree Foam Board, with some wood in places to add shape and support.
Andres has put over 160 hours into building the P-38. The plane now has functioning inboard and outboard flaps set up.
For the Fowler Flaps, Andres made it so one servo controls both the forward/backward movement and the up/down movement of the flap.
Two arms on the outside come off of the servo on a torque rod and control the forward/backward motion. The shoulder arm in the middle controls the forward/backward motion.
Andres used music wire and servo arms that he cut off of servos combined with heat shrink to set up the complex arms.
The foam flap slides on a rail that is attached to the foam board to prevent it from binding. There’s also a small rod that allows for some flex in the flap movement to help prevent damage.
Andres put V bends in his servo wires so they would still work well even if they weren’t cut to the exact length. He also soldered the arms to the torque tube.
The outboard flap servos are hooked up with a servo arm and a large Z bend that matches the center of the servo arm and the outermost hole. There’s another torque rod CA’d and threaded to the servo arm that controls the outboard flap.
Andres created an algorithm for his Fowler Flaps, which you can download here!
Materials:
- Foam board
- Music wire
- Carbon fiber tube or very thick music wire
- Servo arms
- Heat shrink
- CA
- Thread
- Wood or other material to space the rails apart
See more of Andres' airplane in the previous episode linked below.
Here's another clip of his plane flying at the indoor event:
Share your own big builds in the comments, or create an article!
Does Andres already have PDF plans for this?
I am sure a lot of people are interested (as I am) in building this so digital plans for your projects would be fantastic!
Great work! I am subscribed on your channel so will be following your updates...
I will post pictures and info in the build thread as I continue to work on the build.
I am extremely impressed. That is a truly beautiful design. You will go far in aeronautical engineering. Josh commented about how simple your design is. I think that's a huge understatement. The most genius designs use the minimum amount of material to leverage the strength of all the various pieces used. You really did a great job here! Please keep sharing your talent here on Flitetest.
https://drive.google.com/folderview?id=0B3QSs5yLORmRLUNMNEIxaW9YN1E&usp=sharing#sthash.Ljh723TF.dpuf
Enter your known dimensions in the corresponding green boxes. The calculated values come out at the bottom.
I am completly blown away by your work.
As a grandfather, and two of my grandsons are about your age, I am doing my best to keep introducing them, and their 8 younger siblings, and cousins, to projects which I hope will fuel theor inrerests in math and science
Ill be passing this along to them.
I hope that in some way we all stay a bit connected, I anxiois to see what excoting things are uet to come from you and your friends.
Alos, a Vary big shout of "well dome" to your parents, and others, who Im guessing have helped to nurture your ambitions
Blessings,
Bill
I'm a high school technology student working on a wing model for my project and I'm making a flap mechanism based on your design. The layout is slightly different to yours so I can't really use your formula to help me out.
I don't know if your still on here since all these comments are from 2016 but if you do see this, I would appreciate your time to take a look at what im trying to make as this project will go towards my grades.
Thanks.
