Download the template used in this video here:
Sportster Paint Template
3M 77 Multipurpose Adhesive is the brand that we prefer for our templates.
Rust-oleum and Valspar are the spray paints that we think work best on foam board.
Be sure to test your paint and practice on scrap foam board before painting your airplane.
Let us know if you have additional ideas or painting tips that you have!
The get the free plans for the Sportster and the Mini Sportster click the link in the related articles below!
Can you provide a "tiled" templet?
Can you make the templates available in your store? Also the white Gorilla Glue? And maybe the spray adhesive you are using here?
What about using foam safe CA glue and kicker for building the entire planes? (I live in S.E. Florida). Maybe more store items?
i hope this helps
Also for making a template you can use the plans, after you cut out the pieces or poke holes through them to make a template on poster board.
The FT Community Cast went over some cover techniques in Episode 2 that sound super cool. They seem hate the paper on the foam board.
spray 77' glue on naked foamboard and apply giftwrap with sqweegie on both sides.
the wrap rool is 30" and can cover a full board with a continous wrap.
smooth wrinkles with a heat gun and you have a material that weighs 11/2 ounces less than the original 4oz.it can be hot glued and twisted and bend without fracturing or creasing,kinda like EPP foam covered with plastic,it's great!
wally world has lots of this covering,except you cant iron it (even at low temps it melts) but you can any spray paint (light coats) with great results.
my next glider is going to be this technique.
What is the approximate cost of the Hallmark clear wrapping paper?
Thanks.
Thanks for making the Sportster stencils available - I will definitely use these on my upcoming Sportster build :-)
http://alsacorp.com/
