We had a chance to fly some of ReadyMadeRC's latest airplanes and use the FPV Packaged setup to watch some of our flight on an external monitor.
The Anaconda was setup for FPV and we did some formation flying with the Lunar Eclipse.
More details about the RMRC Anaconda - KIT available at: www.ReadyMadeRC.com
SPECS
- Wingspan: 2,060mm
- Wing Area: Approx. 4900cm2
- Length: 1,410mm
- Motor: 35-48 800-1000kv Brusless outrunner
- Propeller: 13x6.5 E or 14x5.5 E (Not included)
- ESC: 60-80A ESC with switch mode BEC
- Servos: 3x 30g and 2x 17g Metal Gear Digital
- Recommneded Flap servos: HS-81/HS-85
- Battery: Li-Po 4s 5,000mAH - 20,000mAH (Additional nose weight needed with smaller batteries)
- Center of Gravity: 1/3 of wing from leading edge at the main spar
- Approximate flight duration: 45 minutes to over an hour depending on configuration
- Fuselage dimensions (Inside): L 66cm (26.5") x W 15cm (6") x H 8cm (3") Maximum measurements
The "mouth" comfortably holds a GoPro but is able to be modified for any type of FPV camera.
ReadyMadeRC Quick Start FPV Package (Monitor, Transmitter, and components)
Here's a list of just some of the items included in this package:
- ImmersionRC 5.8GHz 600mW Transmitter
- ImmersionRC 5.8GHz Uno Receiver
- Spironet Omni Circular Polarized Antenna Set
- RMRC 7" Monitor
SPECS
- Wingspan: 1240MM
- Length: 960MM
- Wing Area: 21dm sq (Mainwing Area)
- Motor: Brushless outrunner motor 2820-3540, 900-1000kv
- Prop: 10x7E
- ESC: 20-30A
- Servos: 9g
- Battery: Li-Po 3s 2200mAH - 3300mAH
- Center of Gravity: 70-80mm from leading edge of wing root
We'd like to thank ReadyMadeRC for the opportunity to try out these great airplanes. Let us know if you'd like to see more on these airplanes in the future!
Be sure to check out www.ReadyMadeRC.com for details about anything you saw in this episode!
