With the popularity of our speed build (scratch build) kits, Chad wanted to share some fast tips on control surfaces for your scratch built RC aircraft!
When cutting the chamfer for your hinges, a sanding block is another great option. Simply hot glue sandpaper to a piece of plywood and use it in place of a razor.
Make your own control horns by cutting a zip tie and drilling a hole for your push rod.
Another great tip for repairing and strengthening your hinges on your foam board airplanes is by squeegee-ing a thin bead of hot glue into the seam.
Hopefully these tips were helpful! Be sure to leave a comment or with any tips that you have!
Thanks for watching! Check out the links below to learn more about the speed build kits and other scratch build tips!
For control horn i use dental floss on stick.
Dan
