Name that Hex...
Introducing the WASP
A big thank you to all the cool folks that submitted names for this!
It has been a struggle to pick only one,with so many awesome submissions.
We have a winner.
Congratulations to Tracks!
Thank you sir!
Pat G's New Mini Hex frame.
Full CF top plate or Yellow G10 top plate.
Light weight 100% pure 3K Twill Weave Carbon Fiber lower plate and arms. 323 mm at the widest and 725 grams AUW with a 2200mah 3s and FPV gear. Arms will fit a range of motors and will accommodate 6 inch props!
The mini hex has greater real estate and payload capacity for a GoPro and all the other toys you can't fit on a mini quad. The hex design also offers the advantage of redundancy - unlike a quad, a hex can remain in the air if it loses a if a motor/prop/ESC in flight.
Just like the Minion quad, the hex is lightweight and tough enough to take a beating, Total frame weight is only XXg and mounting holes sized to hold a 36x36mm flight controller like the Naze32.
The Mini Hex is available with a G10 or Carbon Fibre top plate. The arms and bottom plate are always CF. Some people prefer G10 for its radio transparency.
- 1x Mini Hex Top Plate 1mm CF or 1.5mm G10
- 1x Mini Hex Bottom Plate 2mm CF
- 6x Mini Hex Arms 2.5mm CF
- 1x Mini Hex Camera Mount 1.5mm CF
- 1x Mini Hex Fasteners Pack
Typical setup
- 2204 motor 1960 or 2300kv
- 12A ESC
- Naze32 flight controller or other 36x36mm FC
Canada
Rotorgeeks
BCmultirotors
Hoverallrc
Great Hobbies
US
Ready Made RC
Diyquadcopter
GetFPV
Singapore
