Spidex MICRO from Quaternium multicopters
http://quaternium.es/en/frames/71-spidex-micro.html
Motor distance.
220mm diagonal, 145mm front to back and 165mm side to side.
Here is a mash-up of the first three batteries I put through the Spidex micro.
I had to maiden her at night it was so windy.I have tuned it a bit from what you see here.
This is very definitely a sporty little number!
The tumble at the end was due to wind,nerves,and lack of tuning! lol
Damage..
One busted prop and not a scratch on the frame.
I could here it laughing at my attempted abuse. =)
Next few flights!
Let's see, we have the ESC's wired and wrapped.
Motor wires fit nicely up through the bottom of the frame without any drilling.
I will make the power distribution board smaller and may get rid of the XT60 connectors.=)
If you use ZMR motors, you will need to drill holes for the motor mounts. I used some small washers as well.
F.C. and Bluetooth module in place.
Cppm RX will save some weight!
Simple OSD and slimmed down VTRX
Multiwii needs tuning,I know.I am on it. I don't need to worry much about breaking this frame, it is pretty tough.
just wonder why you use 2 tiny cameras, would it not be better to just use one for both fpv and recording ?
Also, what is the battery life.
Thanks !
I have a kk 2.0 and it is not a easy fit. You would be better off with something smaller like Naze. I am getting 7min or so depending on how I fly. You have video lag when you use a HD cam as a flight cam and the bord camera handles the light better.I fly @ night and this would not be nearly as easy if I used the 808 # 16. I hope this is helpful.=)
Thanks for your answer. Do you think a mobius could be used instead of the 808#16 ?
i have been looking naze32 for a while but conclude that it was quite complicated to set. Maybe cc3d is a good alternative :-)
Aside from that, what do you think of this little hex, would be nice to have a test http://www.minihquad.com/frames/blackout-mini-spider-hex-frame
it looks terrific ! price is high but details are awsomes.
I am not going anywhere without my Spidex micro!
