Spidex MICRO from Quaternium multicopters
Motor distance.
220mm diagonal, 145mm front to back and 165mm side to side.
http://quaternium.es/en/frames/71-spidex-micro.html
Recommended setting:
- 5" props
- Multistar 1704-1900Kv
- Blueseries 12A
- 1000mAh 3S
- RX 5.8Ghz 600mW - 200mW
- Mobius HD
- Naze32
The Spidex micro put through it's paces by the skilled hands of Abormor
When jlcortex ,(jlcortex @aeromodelismovirtual.com)one of the best designers of multicopters on earth,offered to ship me one of his new designs to try,I jumped at the chance!
This Spidex micro quad is a little guy! Only 215mm motor to motor and 70mm tall!
This simple and durable frame is CNC machined from a single billet of POM-C.
Designed specialy for the Mobius HD camera it can fit a second analog FPV camera to avoid latency of digital cameras.
My build started by snipping this frame out with some nippers and sanding marks down in a spot or two.
Ok so, 10-15 minutes later you end up with this.
Ok here is the cool part...
You fit it together with the locking tabs and using no tools you have this!
That is it. Frame is built.
Pretty cool if you ask me!
A place for all yo stuff!
Did I mention it's tiny?
The base of the frame in mine is upside-down to fit the rcx motors.( Thanks abormor!)The frame is designed for the Multistar 1704 from HK.
Ok time to get going! Woot!
ZMR 1804 2400kv motors
RCX 10A ESC Brushless Motor Speed Controller (G Series / Programed for Multicopter - SimonK Firmware)
MWC MultiWii SE v2.0 Flight Controller (w/ Bluetooth Module Adapter)
Here are the battery bay dimensions.
more numbers...
Camera tab hight...
It is snowing out so I am off to build this baby up!
Stay tuned in for part two! =P
ZATO
That is around $50. If it is as tough as has been reported then that is a heck of a bargin! http://quaternium.es/en/frames/71-spidex-micro.html#sthash.N1YTSBVE.dpuf
Efbe
