Transform your Inductrix into a Tiny Whoop!
TJ, known as T-Bone FPV online, showed us how to DIY mod an Inductrix for micro indoor FPV.
To upgrade your Inductrix to a Tiny Whoop, remove the canopy and props. Then unplug the motors and remove the bands securing the wires on the motor mounts.
Use a blunt tool such as a 2mm Allen wrench to push the motors out of their mounts. Make sure the connector doesn’t get caught on the way through.
Check the motor spin orientation by looking at the wire colors. For Micro Motors, the motors with the black and white motors spin counterclockwise, and the motors with the red and blue wires are clockwise.
Insert the connector through the motor mount and slide the motors into place.
Plug motors into the corresponding connectors and replace the bands to secure the wires.
Install the camera by using a splitter from the Inductrix FPV or by soldering the Hyperion 600TVL directly to the top of the battery lead.
Secure the camera using either small rubber bands or a single piece of double sided tape.
Replace the props, and you’re ready to test and fly!
Thanks to Benedikt Haak of Micro Motor Warehouse and RKH Rakonheli for the mod parts, and thanks to T-Bone FPV for walking through this Tiny Whoop mod with us!
Jesse Perkins, Big Whoop team pilot, and creator of the "Tiny Whoop" has a whole youtube channel dedicated to the Tiny Whoop and micro flight adventures! You can check it out here: Youtube.com/TinyWhoop
Mine up and died...looking for options.
https://www.thingiverse.com/thing:1532755/apps/
I got mine from hobbyzone.com
Also, will the Inductrix fly FPV with just the stock motors?
The case http://www.thingiverse.com/thing:1612310
Camera Mount https://www.thingiverse.com/thing:1532755/apps/
This does come in handy if you want to carry the whoop around and not take the FPV off to put in the stock case, Also holds 4 batteries. Good thing work has a 3D printer
http://www.spektrumrc.com/Products/Default.aspx?ProdID=SPMVC1101
I just got a SPMVA1100 micro camera (11mW) and it comes with the splitter.
I also noticed that the front left and back rear motors don't spin hardly at all while the front right and back rear go crazy, causing a mad spin and no upward motion.
Any suggestions?
otherwise its a great little fun machine :)
But now i have a question/problem : i have test flown the inductrix with the 150mA battery which came with the quad and everything was stable. Then i've mounted the camera on the quad (wires soldered to the battery pads) and tried flying with the 205mA batteries. But now the quad seems to fly stable for a minute and then it tilts to the left and falls to the ground.
Is the camera draining to much power from the battery, could it be a faulty motor or is it the Fc?
Currently i'm still using the stock motors
Best,
Pierre
