The Eagle Tree Systems Vector Flight Controller + OSD system is a flight controller designed to work with a wide range of aircraft.
You'll want to check and update the latest firmware in your Vector system. More info. HERE
The setup is pretty straight forward and be sure to read over the user manual before setting up your system.
This is just a quick setup overview, you can get much more information HERE.
It's always good practice to double check all of your connections and keep a consistent color scheme with your wire.
We installed our Eagle Tree Vector system onto one of your ElectroHub quadcopter kits.
Here's the basic setup of the Vector System on the FT ElectroHub, setup with a Fatshark SpiroNet antenna and an ImmersionRC 600mW 5.8GHz transmitter.
The Vector system includes the base controller unit, the GPS/Magnetometer, and the Current Sensor/PSU.
You can always clean up the wires after you verify everything is working correctly.
Always remove props when working with a live multirotor on the work bench.
The Vector system's menu is navigated with your radio.
The OSD system offers a full color display read out.
Even cooler, the colors are fully adjustable to your preference.
You can learn more about the Eagle Tree Systems Vector Flight Controller + OSD HERE!
1. If you have a 5 volt camera and need to power it and the reciever from the Vector, you will need a servo Y-harness to get that done. No big deal but worth mentioning.
2. If your electrohub is already built, most likely you have everything powered via the center plates since they are PDB's. In that case you will need to connect the power harness that usually plugs into your battery into the 12v out on the Vector PSU. Again, not a big deal and maybe common sense to most but I was so focused on wiring everything up that I forgot that I needed to power my escs! Doh!
I haven't had a chance to do any flying more than hovering in my garage but so far I am super impressed!
