Here's a fast, cheap option to mount your camera onto your AnyCopter. This setup is designed to isolate vibrations of your multi-roto in your on-board camera footage.
Using some scrap wood and some galvinized steel wire you can create this rig and install it quickly.
Measures of the components in Chad's design:
Galvanized Steel Wire: 15" inches
Wood (bass/balsa): 9-1/2" inches
This is just one of many options that you can try on your Rotor Bones AnyCopter!
Want want to see your designs and ideas! Submit them in the forums! CLICK HERE
Gonna go downstairs to the basement and build me one. Then I'm gonna crash it and build a new one, but this time with camera tilt. Perhaps combine this one with the easy wooden camera tilt you guys built about a year ago. This one: http://flitetest.com/articles/DIY_Simple_FPV_Pan_Tilt_Setup_Build
Tommy Gunn
What gauge wire are you using?
Also the clamps you are using are hemostats, but are called a number of things including arterial clamps or forceps, Kelly clamps, etc.
http://en.wikipedia.org/wiki/Hemostat
Works great!
thanks FliteTest!
