This is a new version of my previous scratch built the Delfer. The overall wing area is smaller and gives it a nice quicker reaction with the ailerons. I wanted to build a plane that was simple to build for a beginner like my self and that was small enough to fly in a small school play ground. This version has a 7.5 prop but I think it needs to be changed to get more bite. I t currently flys real nice and slow if needed. Loops are a bit of a challange as it needs more prop. It only took me about four hours to build from printing plans to flight ready. The video is the maiden. The plane is a little touchy on aileron rolls as it was on high throws unknown to me at the time .
Here are the plans all laid out and taped ready for transfer
All the parts are now cut out ready for assembly
Tail assemby complete. (Same assembly as the FT flyer)
All ready , now for the electronics
Servo installation and battery location
All done Ready for maiden
heres a closer view of the elevator and rudder connections
The plans are in CAD format There should be free software out there to change it to pdf
Specs. for this plan are as follows
Motor 24 gram blue wonder 1300kv
600 mah battery
7x5 prop
20 amp esc
9 gram servos
used powerpod from Flight test design
Landing gear work great video was just a test flight
t I have now put a pdf tiled version just above the spec. list hope this helps
Let me know how you make out with the flights
Trying my design ,especially a successful one . Your right this is a fast plane compared to the first version
Which I still fly today as a relaxing flight. I hope you enjoy it for along time
Once again thank you it is appreciated
